To Build A J35A3 Short Block + J32A2 Heads??
Old 12-28-2012, 09:18 PM
03 CLS-6
1foxbody's Avatar
Talking To Build A J35A3 Short Block + J32A2 Heads??
I decided I want to build a engine on the side while my cl is still running and driving, to have the least amount of down time. I can't decide what combination to build exactly. I also want to only use oem parts and keep the price to a minimum, since at the end of the day I'm still going to be spraying the hell out of the engine lol. I'm leaning towards buying a J35A3 engine since I can buy one cheap and putting my J32A2 heads on it.
The only problem I would run into from doing some research and talking to a few people is I would have to get different pistons to clear the 36mm intake valves. Does anyone know 110% I can't just keep the stock mdx pistons installed when using my J32A2 heads? I'm also going to do a few other things while I have the engine on the engine stand to make working on it easier while it's out of the car. Things like complete timing belt service, gude performance cams, supertech valve spring + retainers, porting / polishing, powder coating some parts.
Help me decide what to do people, to many choices lol!!
Here are the swap options along with brief advantage(s)/disadvantage(s):
BLOCK/HEADS (incl. manifold (upper/lower), tb)
J30A1/J30A1
advantage: no modification needed.
disadvantage: no torque until turbo/sc kicks in.
J30A1/J32A2
advantage: mid-range and top-end power
disadvantage: J30A1 pistons have to be modified to fit large J32A2 (intake) valves.
Not much torque until turbo/sc kicks in.
J32A2/J32A2
advantage: no modification needed, mid-range, top-end power.
disadvantage: torque is still ok but better than J30A1
J35A4/J30A1 (Odyssey '02-04/ '00-02 Accord V6)
advantage: no modifications needed, adequate torque, adequate mid-range
disadvantage:needed better cams, large intake valves for overal better powerband, top-end power
Option 1:
If budget is limited the solution is to swap J32A2 (CL-S/TL-S) cams into stock J30A1(Accord V6) cyl. heads (see sticky CL-S swap and Cam machining).
Option 2:
Get J32A2 (CL-S/TL-S) complete cyl. heads + IM (intake manifold)
But requires different pistons (see J35/J32 below) to clear J32A2 valves.
J35A3/J35A3 (Acura MDX '01-02), J35A4/J35A4 (Honda Odyssey '02-04)
advantage: no modifications needed, great torque, nice mid-range
disadvantage: little less air flow than J32A2 but very close.
This option looks like a good choice if getting the complete engine or even separate short block and cyl. heads/manifold due to a price. And MDX the cyl. heads are the same part # as CL-S, however intake valves and cams are different than CL-S but overall much better than pathetic AV6.
J35A1/J32A2 (Odyssey '01/CL-S '01-03)
advantage: great entire powerband and especially torque.
disadvantage: Need CL-S or RL pistons.
Note: Same options apply as listed below.
J35A3/J32A2 ('01-02 MDX/CL-S '01-03) or J35A4/J32A2 (Odyssey '02-04/CL-S '01-03)
There are also couple options:
Option 1
With '01-02 complete MDX block or '02-04 Odyssey complete block (crank/rods/pistons) it is required to purchase 2005 Acura RL pistons (new set $50 each) This is a best option still since these pistons have clearance for large 36mm J32A2 (intake) valves thus no modification needed. Despite the fact they have higher 11.0:1 CR still even supercharger can be used here with low boost up to 7psi intercooled (assuming safe AFR). In addition, if 11:1 CR is too high for you, you can use '03 CL-S pistons with 10.5:1 CR.
Option 2
'01-03 J32A2 block (CL-S)
Required to purchase the following:
-= hondaautomotiveparts.com =-
'02-'04 Odyssey (crankshaft)
Product No. 368270 or
Honda part #13310-PGK-A00
'02-'04 Odyssey (connecting rod)
Product No. 368269 or
Honda part #13210-PGK-A00
Main bearings + rod bearings
-= acuraautomotiveparts.org =-
'03 CL-S (pistons) - 10.5:1 CR or
'05 RL (pistons) - 11.0:1 CR
pistons rings (per chosen model)
Note: Odyssey pistons do not have clearance to fit large 36mm J32A2 (intake) valves. Solution - custom job to increase valve pockets.
BTW, The only advantage to get J32A2 block is due to better cylinder sleeves to withstand heat designed for higher redline vehicle, otherwise depending on the price Odyssey or MDX block are the best bet.
Keep in mind, J35A5 '03-04 MDX will not fit on 6th gen. AV6/CL/TL/CL-S/TL-S due to different design, and looks like only for 7th gen. AV6.
Edit: The correct valve dimensions now stand as follows: incl. J30A4/J32A4
J30A1 '98-02 AV6: 34mm/29mm (intake/exhaust)
J30A4 '03+ AV6: 35mm/30mm
J32A1 '01-03' TL/CL: 34mm/30mm
J32A2 '01-03 TL-S/CL-S: 36mm/30mm
J32A4 '04+ TL: 35mm/30mm
J35A1 '99-01 Odyssey: 34mm/29mm
J35A4 '02-04 Odyssey: 35mm/30mm
Old 12-28-2012, 09:31 PM
njlakeshoreg's Avatar
my head is spinning homie......lol
The following 3 users liked this post by njlakeshoreg:
1foxbody (12-28-2012), mikebikelife (12-31-2012), Sonnick (12-31-2012)
Old 12-28-2012, 09:52 PM
3.5 psi
gnuts's Avatar
i think this thread seems to have the info you need:
https://acurazine.com/forums/showthr...=714305&page=5
specifically this post:
Originally Posted by MoneyPit
It's not that the valve reliefs were "bigger than needed," but it's a combo of a few things. The valve difference isn't actually a full mm (35.51mm vs. 36.0mm), and the J35 pistons are a lower comp so the compression deck height is larger. From the naked eye, it would appear that the valve reliefs would never clear, but the illusion is due to the dish, making the reliefs appear very small as compared to the J32A2. This is probably the reason the "myth" was spawned.
I wish I could speak about the newer J configurations, but I don't have any personal experience with them.
1foxbody (12-30-2012)
Old 12-28-2012, 11:43 PM
03 CLS-6
1foxbody's Avatar
I didn't read the first four pages of that thread but is he specifically talking about the exact combination I'm talking about? He said he puttied it and the clearance was fine. So maybe I will be okay and it's all a myth lol. I'm curious to what the new compression ratio would be with this setup too..
Old 12-29-2012, 12:20 AM
J-series addict
yungone501's Avatar
Now you're speaking my language Fox!
What they IS TRUE, you cannot use stock j35a3 pistons with 36mm valves unless theyre notched. RL (05+) and TL-S (07-08) pistons will def clear 36mm intake valves. Although many (including myself) have denounced that the RL/TL-S pistons are forged, Acuranews.com actually says that they are...that's official too. I myself DID see, in person, casting marks on the one I ordered for that reason alone. If you're wanting to stick with OEM parts only, I'd recommend using the 09+ TL 3.5 pistons. They're forged aluminum and are around $75 cost for a standard set. But you may want to reconsider if you must use oversized pistons (.020") because they're nearly $160 per piston! If you need them, I can give you factory cylinder tolerances that you can use to determine wether or not a bore or just a hone is required. I've heard a lot of rumors on how the larger stroke J series motors develop "square" bores due to the linear force caused by the rod stroke itself on the walls. Chances are it will require boring unless you can find a low mileage unit.
As for the heads, I've heard from two trustworthy people that the factory j35a3 heads have more airflow potential than the j32a2 heads but I've never seen any flow charts to verify this. If you're looking for the cheapest route, I'd just stick with the j32a2 heads because it would cost some extra cash on enlarging the j35a3's valves.
Old 12-30-2012, 04:08 PM
03 CLS-6
1foxbody's Avatar
Thanks for the reply! Maybe I'll just keep the J35A3 heads on and do a little porting/polishing to them since they are very similar anyways. Do you know what the compression ratio would be if I just kept it that way? That seems like the cheapest route. So are you 110% sure my J32A2 heads won't work without fly cutting the J35A3 pistons??? I might just try it for shits and giggles. It's not that hard to check piston to valve clearance on a engine stand.
Another option is I can always use cl or rl pistons and just do a quick hone. I wouldn't get it bored because that's even more money added to the total lol. But that's another $500 roughly for pistons and ring set added to the price of buying the engine. I don't think I want to go this route.
I need to make up my damn mind lol!!!
Old 12-30-2012, 04:56 PM
03 CLS-6
1foxbody's Avatar
After doing some more research I think the compression ratio of a bone stock J35A3 is 11:1:1. Also if I put my J32A2 heads on it the new compression ratio would be 11:5:1. Can anybody confirm that?
Is it possible to reuse the head gasket and head bolts?
I think I'm going to just try to do it out of curiosity.
Old 12-30-2012, 07:52 PM
gerzand's Avatar
13010-PGK-A01 pistons DO clear 14711-PGE-A00 valves. Forget what you may have heard, as I'm a guy who has seen it work.
The front head part number of a J32A2 is 12100-P8E-306. A J35A3 is 12100-P8E-306 as well. The same goes for the rear heads of course since neither motor used VCM.
Yes, the J32A2 head will give you a .49 bump in compression. I took CC's as well and did the math.
You shouldnt re-use head gaskets or head bolts. They are torque to yield.
The following 2 users liked this post by gerzand:
1foxbody (12-31-2012), DEPTLS (02-13-2014)
Old 12-30-2012, 08:06 PM
Stephen00TL's Avatar
I've been debating what to do, I'm thinking about getting an mdx or pilot 3.5 motor and throwing all my mods on it once I get my tax refund.
Old 12-30-2012, 08:42 PM
gerzand's Avatar
Also, keep in mind that you'll still be 10.5:1 with a j32a2 head on a j35a3 shortblock due to 13010-PGK-A01's small dome. The j35a3 is 10:1 from the factory
Old 12-30-2012, 08:59 PM
(i have the setup in my garage, recently disassembled getting ready to bore out to make room for the J37 parts)
which is the main reason to upgrade to the RL or TL-S pistons. To get higher compression.
Old 12-31-2012, 12:10 AM
03 CLS-6
1foxbody's Avatar
Thank you gerzand you answered all my questions!!! Now it's time for me to get to work lol!!
On a side note my friend dropped off his 03 CLS 6 speed swap tonight for me to do some work before he has it swapped into his ek civic hatch. I only took two pics after putting it on the engine stand.
Old 12-31-2012, 01:50 AM
@Mikeshlong On IG
mikebikelife's Avatar
The jseries looks huge outside of the standard engine bay , and even larger in a civic ...
Interersted in watching all you do in this build . Will keep reading .
Old 12-31-2012, 06:51 AM
I love how every J the rear head gets discolored inside while the front stays nice and new looking.
Old 12-31-2012, 07:35 AM
03 acura cl type s
rush's Avatar
Old 12-31-2012, 08:16 AM
J-series addict
yungone501's Avatar
So Fox, I must ask...I understand the whole wanting to use OEM parts but why spend $500 on stock pistons? Going through a reputable company such as Wiseco you will get both the quality and the value. I myself chose Wiseco for my J32 build and had a chance to take some measurements and was amazed at the tolerance they held to the OEM pistons.
Also, are you planning on running this with factory ECM? If so, which one?
Old 12-31-2012, 09:56 AM
All motor
Sonnick's Avatar
Sub'd!
When are you going back to the track!? Lol.
Old 12-31-2012, 11:43 AM
03 CLS-6
1foxbody's Avatar
I was just showing that option for reference. I'm not going that route lol. I'm doing it cheap as possible because I still have a large chance of breaking something in the short block since I'm using a lot of nitrous still. I'm actually going to jet the shot higher since I'll have the direct port kit on. I'm still going to use my oem pcm. I'm going to talk to msd to see if they offer some type of ignition box and/or timing retard for distributorless ignition systems. I doubt it but it's worth a shot.
Old 12-31-2012, 11:45 AM
03 CLS-6
1foxbody's Avatar
Originally Posted by Sonnick
Sub'd!
It doesn't look like until the 2013 season in spring lol. I'll definitely be at the spring track meet!! Hopefully they kick my ass out for going faster than 11.50's without a cage haha .
Old 12-31-2012, 11:59 AM
6mt swapped..smart
AnthraciteTypeS's Avatar
So in actuality, you could just throw your a2 heads on an j35a3 bottom end netting you the same 10.5:1 stock compression.. If i'm correct, that's the route i'd go. Do the j35 bottom ends comply while reving to 7000k+ though?
Old 12-31-2012, 12:13 PM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,414 Likes on 3,024 Posts
Old 12-31-2012, 12:45 PM
03 CLS-6
1foxbody's Avatar
Ding ding exactly what I'm doing. The only thing I'll have to buy is complete timing belt kit, head gaskets, and head bolts. I have some big plans for a custom upper intake manifold setup. Remember I'm also doing gude performance cams, supertech valve springs/retainers. I would like to at least make 300+whp. I know the oem pcm will be leaving some power on the table but it's worth the sacrifice for reliability.
I think the shortblock will be fine. Will see how long it lasts on the big shot though lol.
Old 12-31-2012, 01:32 PM
6mt swapped..smart
What about the revving aspect or are you not going to rev it out to the stock 3.2's computer's limit? I can't believe you're doing all this without any tuning..Don't be surprised if the stock ecm has a shit fit and forces you to throw something on there.. I know mine did when I ported the heads and added a lot of air through pretty much every other intake-breathing mod you can do
Old 12-31-2012, 03:08 PM
The 3.5 will be just fine reving to the type-s redline. Many have done it (on other forums) There shouldnt be a issue with porting and the stock ecu either. I have everything ported on mine and have zero issues. I even had a 80mm tb on with the stock ecu and had no issues. These motors NEED more air, the more you can get them the more they like it.
Old 12-31-2012, 04:31 PM
03 CLS-6
1foxbody's Avatar
X2 Exactly what you said lol! Wait till you guys see what I have planned for the upper intake manifold and throttle body setup.
Old 12-31-2012, 04:54 PM
blue02S's Avatar
I thought the J32a2 only had a 9.8 to 1 compression ratio.?
Old 01-01-2013, 12:02 PM
Not unless something is wrong with the motor
Old 01-01-2013, 12:14 PM
03 acura cl type s
rush's Avatar
Lol
1foxbody (01-01-2013)
Old 01-02-2013, 06:32 AM
that is one way of putting it
The following 2 users liked this post by fsttyms1:
1foxbody (01-02-2013), Sonnick (01-02-2013)
Old 01-02-2013, 02:17 PM
All motor
Sonnick's Avatar
Ported 3.7 manifold? Or dual TB perhaps?
Old 01-02-2013, 03:19 PM
3.7L Nitrous Breathing CL
richardparker's Avatar
j32a1 has 9:8
Old 01-02-2013, 10:18 PM
03 CLS-6
1foxbody's Avatar
Completely custom upper from scratch with ported lower runners. I won't spill all the beans so the anticipation kills you guys lol!
Sonnick (01-04-2013)
Old 01-02-2013, 10:42 PM
03 CLS-6
1foxbody's Avatar
Scratch that. Not using the oem lower runners anymore since they can only be bored so much and a limiting factor when it comes to designing a new manifold. Everything will be custom. Also aftermarket fuel rails, new direct port setup design too.
Old 01-03-2013, 05:46 PM
03 acura cl type s
rush's Avatar
It's me mrs CLEO I see this in your future
Attached Thumbnails To Build A J35A3 Short Block + J32A2 Heads??-f84faa84.jpg
Old 01-03-2013, 07:17 PM
03 CLS-6
1foxbody's Avatar
That's a pretty neat setup but mine is going to be way different. Nothing like ever seen before!!!
Maybe I'll post a few pictures of very similar V8 setups. They a pretty much the same design minus two cylinders.
Old 01-03-2013, 08:30 PM
J-series addict
yungone501's Avatar
Not to be rude or anything Rush, but I think mine actually look better...
Built them last weekend while waiting on my wife to finish cooking dinner.
Attached Thumbnails To Build A J35A3 Short Block + J32A2 Heads??-ee9d49e7f4f8bc9e82d235907de896d3.jpg
Old 01-03-2013, 08:43 PM
gerzand's Avatar
VG30's for VQ35, no?
Old 01-03-2013, 09:36 PM
03 CLS-6
1foxbody's Avatar
Now that's what I call talent and getting shit done quick lmao!!
Old 01-04-2013, 06:22 AM
Now that is
Old 01-04-2013, 08:37 AM
All motor
Sonnick's Avatar
WTF is going on in here? Lmao.
The following 4 users liked this post by Sonnick:
1foxbody (01-05-2013), AnthraciteTypeS (01-05-2013), Stephen00TL (01-04-2013), yungone501 (01-04-2013)
Quick Reply: To Build A J35A3 Short Block + J32A2 Heads??
