| Welcome to Acurazine.com! |
Thread Tools |
#1 | |||||
Brake Caliper Lube/anti-squeal
Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Spoilers and bodykits are how much of the wall you take with you. Rollcages and windownets are how much of a mess you leave on the wall. |
| Sponsored Links | ||
#2 |
ridin slow'n'low
I used permatex. brembo oe blanks, hawk hps pads, legend calipers, no squealing.
#3 |
you can get a little package at the counter of your local parts store for $.99. 1-2 packages will do an entire brake job.
#4 |
forgot to say... it looks like a package containing ketchup... kinda like the ones you get from mc donalds.
#5 |
Tacky stuff is disc brake quiet. You are only supposed to use that stuff if the pads are shimless. Shimmed pads use disc brake caliper grease only...supposedly.
#6 |
Wurth Anti-Squeal on the pads and paint the feet with copper paste. This is what we do on the cars at work and I have never had problems with the brakes squealing.
#7 | |
Mega Moderator
2003 Acura CL |
#8 |
I'm speaking of the synthetic grease not the rubbery crap.
#9 |
I talked to CRC again today and apparently this entire brake lube plot gets thicker.
The definition of shimmed by CRC and other polymer industries than what many pad manufacturers consider as shimmed. CRC's engineers state that brake pads with a slice of metal built right onto the backing plate (they call this a metal gage riveted to the backing plate) is NOT a shimmed brake pad. The only pad design they consider to be "shimmed" are pads with actual, separate shims like those that are featured in the OEM pads. Shims that are detachable and must be user-installed. Any pads with riveted, pre-installed metal pieces that are not user removable are not considered shimmed pads. Thus, nearly all of the aftermarket pads we use on this forum: EBC Greenstuff, Hawk HPS, Raybestos, etc should be using the tacky CRC Disc Brake Quiet compound (or Permatex brand one), not the synthetic disc brake caliper grease that I had mentioned earlier. My error. The only pad designs that are supposed to use the grease are the Honda ones with the user installed shims. Hope this clears everything up... |
| Tags |
| anti, brake, caliper, grease, lube, lubricant, lubricate, pad, pads, raybestos, silicone, slide, squeak, squeal, susposed |
| Thread Tools | |
