Yellow Faded Headlights???? There is a cure!!!
Old 08-23-2003, 06:24 PM
athlonxp's Avatar
After having painted my car and color sanding and buffing, I tried it on my driver's side headlight and believe it or not, they are clear as if it were brand new.
What you will need are the following items.
600 grit wet-able sandpaper
1000 grit wet-able sandpaper
1500 grit wet-able sandpaper
3M rubbing compound
1400-1700RPM polisher
Wool Bonnet
All sanding that is done must be done by wet sanding. So you must soak the sandpaper in a bucket of water and let it marinate in there for about 15 minutes. Cut each type of the sandpaper into thirds then take one of each and fold that into thirds. Then put those three pieces into the bucket of water, go take a coffee (or beer) break and return in 15 minutes.
Now, start off with the 600 grit if there is heavy buildup or if you want the job done faster if not then start with the 1000 grit. But faster may sacrifice quality. Splash some water onto the headlight and sand down all the buildup (the yellow stuff) and until the headlight's lens is all blurred with rather visible scratches from the sanding, don't worry here, no you didn't just @$&#*$-up the headlights.
After the 600 (or 1000) move on to the next grit and sand until you notice that the scratches become finer. If the fine scratches are consistent throughout the headlight then move to the next grit. Sanding with 1500 grit should show no scratches only that the headlight will still be blurred. No worry still, polishing will take it out.
Now it's on to the buffing/polishing. Well, of course clean the headlight with water and wipe it dry. Now take the rubbing compound and dab some across the headlight. Take the buffer with the wool bonnet attached and without turning it on just spread the rubbing compound. Now start up the buffer and start buffing away in a side to side motion going from top down. As the buffing continues and as the compound starts drying you'll notice the headlight becoming smoother and clear once again. Continue buffing until all instance of the compound has disappeared and stand back to be amazed!!!! It will look as good as new.
Despite what others may think of the yellowing in the inside...it is contrary to that as it is buildup on the outside.
Hope this tutorial helps you and saves you from having to purchase new headlights.
An entry level polisher which works marvelously is that from Sears. It is a Craftsman 4.5amp, sander/polisher with 2 variable speeds and comes with the wool bonnet. It costs $59.99.
The sandpaper would run you about $10 from any autoparts store and the compound is $6. So in total you would spend about $80 to have headlights as good as new than to spend $400 for a pair of brand new headlights.
Well, peace out, just sharing some invaluable experience I think that might help out some of you!!
Old 08-23-2003, 06:47 PM
Stapler's Avatar
I just used some odd stuff that smells like bear piss... Your way sounds better just cuase of the smell.
Old 08-23-2003, 07:23 PM
athlonxp's Avatar
Actually I've tried every chemical agent out there and none of them seem to work. And so I resorted to this. I've used everything from acetone to hydrochloric acid and none of it has ever worked. Whatever build up it is...it's tough. It may take a little work but I think it's worth it!!!!
Old 08-23-2003, 07:58 PM
Homeless
chef chris's Avatar
They also make 2000 grit wet/dry...
I'd start high & work your way down as some folks might not have really bad discoloration. You can always do a lower grit if it doesn't do the trick the first time around. I've also used RainX windshield polish for slight plastic oxidation, worked ok.
Worked on my old max.
Old 08-23-2003, 08:03 PM
The hair says it all
Python2121's Avatar
where, exactly, is this discoloration? the bulbs, or the lenses?
Old 08-23-2003, 08:31 PM
Homeless
chef chris's Avatar
The plastic lenses...
probably the most from UV light & road chemicals, etc.
Use to happen often to my old m/c windscreens...
Old 08-23-2003, 08:38 PM
athlonxp's Avatar
I've realized that they do make 2000 grit wet/dry however with the buffing compound anything at 1500 grit or above it polishes out completely.
I mentioned to use 600 grit if it's really bad discoloration otherwise working from 1000 grit and then to 1500 grit. Working from top down may usually end up in having to polish more than once. Since you try doing 2000 then polish, ok not too good, so you go lower then polish, still not good, so you go lower to 1000 then after that back up to 1500 and then polish. More steps involved. But then it's up to the owner to discern how much discoloration there is. Either way as long as it's above 1500 grit the buffer will clean and smooth it out. So whichever way you go just make sure the last sandpaper used is 1500 grit or above.
I have a 97 and so I'd consider I had high discoloration.
Old 08-23-2003, 11:07 PM
RippinRide's Avatar
I was wondering how to take care of this i was about to try the exact same thing just as i would on paint scratches. Im glad to hear that you have good results. I think i may work on my car tomorrow and do this and repair tiny holes that are in my passenger side door panels in the vinyl. I was talking about this about a month or so ago.
http://www.acura-cl.com/forums/showt...ing+headlights
Did you take out your headlights to do this?
Old 08-24-2003, 04:09 AM
athlonxp's Avatar
No you can just leave them on the car. Worst case scenario would be that you would buff the area around the headlight. But is that really bad...ooohhh shiny!!!! hehe
Old 08-24-2003, 11:06 AM
CL smashin
Outlaw's Avatar
Where can I get that wool bonnet? I have a craftsman buffer too, but it only came with a terry bonnet. About how long did this take to do? And do you got any before and after pics?
Old 08-24-2003, 11:22 AM
infamouz trunkz's Avatar
im just wondering how come the drivers side is yellowin up?
Old 08-24-2003, 06:52 PM
Homeless
chef chris's Avatar
Pep Boys sells wool bonnets.
Old 08-30-2003, 11:46 AM
Stylin CL
Epoc's Avatar
Wow, i've tried so many different things to clean the headlights and this actually worked they look brand new. Thanks for posting this athlon it helped me out alot.
Old 08-30-2003, 12:32 PM
yo u got any before n after pics
Old 08-30-2003, 02:55 PM
Work safe avatar bish :D
nandowong's Avatar
everyone should try it. it really works. i posted this almost a yr ago but i did not use a buffer, instead i used my two phytons (popeye size arms and tooth paste instead of the compound. i only spend four bucks on 3m 2000 grit and just went at it with that. by the time i was done i could not feel my arms, but the car looked a lot better. wel worth the time
Old 08-30-2003, 03:37 PM
djz
Music for your Mind......
djz's Avatar
I just did this myself and the car looks WONDERFUL!!!!!
I had a polishing buffer and went to town on them. It didnt take very long, it actually took more time shopping for the items then it did to fix the headlights!!!!
Thanks AthalonXP!!!
Old 05-26-2009, 02:03 PM
guest's Avatar
It Worked
THANK YOU!!!
Did this by hand with foam sanding block. Used a drill for buffing [rubber covered with wool pad]. May not be the best results, but is way better than before. I can see the lamps again and it looks clear.
thank you so much for posting this!!!
Al F.
Old 05-26-2009, 02:07 PM
Custom User Title
Gnate's Avatar
:backfromthedead:
Old 05-26-2009, 02:15 PM
f22vtec's Avatar
i did this they went back to normal after a couple months nice write up tho
Old 05-26-2009, 02:25 PM
Josh99CL's Avatar
You'll want to use some type of covering to maintain the results(something with UV protection).
I was reading about headlight polishing in the wash & wax forum the other day.
I think you can get a kit for like 50$ per light that should maintain the results forever basically.
Old 05-26-2009, 03:15 PM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,414 Likes on 3,024 Posts
You can get the 3m kit for $19.95 at most auto parts stores
Old 05-26-2009, 03:16 PM
on1wheel01's Avatar
wow back from dead yea. But I did mine with some help from my budds high speed buffer and some specialk compound thats like $50 a bottle or something. They look like new and have stayed that way for quite a few months
Old 05-26-2009, 06:02 PM
Blazin Si's Avatar
I need to get my hands on a buffer.
Is there any sort of liquid acrylic that we can coat the lenses with? Something like the OEM coating with UV protectant?
Old 05-26-2009, 10:06 PM
(Mid-Atlantic)
Buffer after sanding for sure, and some plastic polish, haven't touched mine, but they're in pretty good shape minus some overspray
hashbrown
02-18-2022 11:20 AM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Mr.Tea
10-02-2015 10:32 PM
Quick Reply: Yellow Faded Headlights???? There is a cure!!!
