06 oddy trans in my 02 cls
Old 04-17-2014, 08:50 AM
Vtecv6s's Avatar
Well I recently just finished my oddysey swap from a 06 and everything went really smooth for the most part. One thing I did notice is that the housing for the axels was slightly bigger and may have offset my driver side axel making it a shorter distance from the trans to the hub. So the issue that im having right now is that the driver side axel makes a grinding noise when I make right hand turns going over any bumps. I went out and bought a new axel that maybe has 200 miles on it and it is making the same distinct noise as the old one. It basically sounds like your driving over the center reflectors in the road when weight is distributed to the driver side while turning right. I would like to know if anyone else may have had the problem on their swaps or how i would maybe go about getting a different length axel. Any help would be greatly appreciated. Thank you for taking the time to read the post.
Old 04-17-2014, 10:38 AM
YeuEmMaiMai's Avatar
try oddessy axle?
Old 04-17-2014, 01:16 PM
Vtecv6s's Avatar
Yea that was my second option, I just wanted to see before I go out and buy a second axle.
Old 04-25-2014, 06:00 PM
Vtecv6s's Avatar
The oddysey axel is actually longer
Old 05-12-2014, 09:13 AM
Vtecv6s's Avatar
Hellllp please no other suggestiins anyone? Nva6
Old 05-12-2014, 11:46 AM
lowrd on tein CS biatch
CL-S progression 01's Avatar
Worst comes to worst if that is in fact the problem u could just get the axle shortened, by a professional that balances it after.
But I am sure that is going to be a few hundred beans so u better be sure that's it
I would try and get measurements off another CL to see how much u are actually out, then work from there
Vtecv6s (05-15-2014)
CL-S progression 01
01-26-2016 04:15 PM
Oakroadsteve
10-28-2015 10:28 PM
LeVeL
10-18-2015 04:19 PM
steve
09-30-2015 09:23 PM
flyromeo3
09-24-2015 11:24 PM
Quick Reply: 06 oddy trans in my 02 cls
