Need help acura cl type s clutch kit installation
Just did my clutch master clutch kit now my car won't pass 2 k rpm throwing codes for crank positioning sensor and map sensor but with the stock clutch it was fine can some one plz help and also the aftermarket flywheel don't got the pin that the stock one has was I supposed to remove it and install it on the light weight one
3.5 psi
Not sure what to tell you but it seems others have had the same problem:
https://acurazine.com/forums/showthr...=864323&page=2
i really need the help.I would like all the help i can get.But i called clutch master and they told me i need to install the pin that my stock flywheel brings.And i didnt install that pin to my aftermarket flywheel .Hopefully thats the problem.Karanx7 so if u can be a nice guy and help a fellow member that will be very much appreciated.Thank you very much
o0o0o0 (04-08-2014)
When u bang it out did it get damage. Because I was trying to pull mines out with plyers. And the corners got a lil ding up. Does that matter that they got a lil dinged up
Vic87 (04-08-2014)
Back to square one. Took the fucking trans back out reinstall it with the pin and still not fucking wrking. What else can the proble be. No one should buy clutch kit from clutch master
IIDXholic
10-08-2015 07:53 AM
nuldabz
09-03-2015 05:49 PM
