'01 acura cl rough start
Old 02-14-2014, 09:50 PM
jacob5m's Avatar
Hi,
my '01 acura cl has trouble starting after long drives and moderate heat temps. . the car wouldnt idle correctly, almost sputtering but with gas it eventually catches. I replaced the fuel relay but the issue still occurs.
any ideas on what the issue may be? The main relay?
Thanks for your help,
jacob
Old 02-14-2014, 10:25 PM
YeuEmMaiMai's Avatar
idle air control valve?
vacuum leak?
fuel pressure regulator
mileage on car?
Old 02-15-2014, 07:38 AM
lowrd on tein CS biatch
CL-S progression 01's Avatar
cars can idle with a vac leak when col cause everything is running in "open loop" cycle.. this is where the car has predetemined perameters that is follows until everything heats up and the the sensors take over and the car functions off that..
so if it starts in the morning when cold, and idles rough or idles high then u almost certainly have a vac leak.
check the intake system, check the boot that connects the vsa to the intake system, and check everywhere else slowly and thoroughly.
grab things and move them a bit which may make a small crack on a line visible.
if u dont have a vac leak then i would look into the IAC.
when the car is running fine, disconnect and see what happens... when the car is acting up, then remove the iac connector again and see if there is a change... if there is not its likely the iac i would think
Old 02-15-2014, 02:24 PM
jacob5m's Avatar
My Cl has 95k miles
The car runs fine on cold starts just when the car ha been running for about an hour. So it may be I iac. Can you tell me where it is and how to take it out
Old 02-15-2014, 11:50 PM
poisx7's Avatar
Originally Posted by jacob5m
My Cl has 95k miles
I think it sounds like IACV issues.
also maybe sea foaming the tank might help a lil.
Old 02-18-2014, 06:24 PM
jacob5m's Avatar
Hey, I took my car into the dealer and it was the IACV (clogged). Thanks for all your help!!
Old 04-15-2014, 05:36 PM
stephenhaze's Avatar
idle air valve
Had similiar problem. Mine would idle when just started but would stall out while driving if clutch was pushed in. Cleaned idle air valve and problem was solved.
saberlove
03-11-2021 09:29 AM
kuzdu
09-10-2015 08:42 PM
NSolace
09-03-2015 08:14 PM
NSolace
09-03-2015 08:02 PM
Quick Reply: '01 acura cl rough start
