CL Make Over
#83
so im doin the RL BBK upgrade on the car but i was wondering if i should go with the ebc Green stuff in the front and the Red in the back or go Red all around?
#84
went by the dealer ship today......just out of the spray booth....
they took off the door windows and bumpers so there is no paint lines
4 base coats and 5 clear coats
#85
went to check up on the car again they have the doors back on and are goin to start buffing it and when i left they were working on repairing the interior
#86
Recently turned 18
Looks good from the photos but a detailed inspection will reveal the truth. Have one question, can't remember if you stated it before but why did you just go back to black? I would've went with a different color if I was doing a complete repaint on a black car.
#87
well buddy i they are not painting the engine bay or the the inside of the doors they are painting the whole exterior plus i like the origanal two tone color where it has a tint of blue in the sun but still looks black i had them add a bit more pearl so the blue can stand out just a bit more but you cant really notice it ..... what color would you gone with ....white???
#88
Recently turned 18
I'm not sure what you're saying. Hopefully you weren't taking my comment as insulting. I was simply saying if I had the opportunity to paint a black vehicle entirely I would try to go with something different. White is cool as hell at times but I don't think I would change it TO white. Hahaha I think there are a lot of colors I have pondered over the years. The CL needs a perfect shade to really compliment it's subtle presence. Gunmetal, orange, green, light grey, accord purple, blue. It's not my money or my car but I was throwing a couple pennies out there. Look forward to the finished product.
#89
no im not taking it insulting i was being honest alot of peopel seem to like the white color but no i really do like the black color have you seen it .... it has a bit of blue in the son really looks nice to me honestly i would either would of done white or black thats just what i like the finish product should be here by this friday
AustinTaper (04-22-2012)
Lance10 (10-25-2015)
#94
Whats up with RDX owners?
Not bad.
SimonCL-S6 (05-01-2012)
#99
Those lambo doors have been pleased out...
On Topic : I don't mind the doors, but I wouldn't put em on my CL (I'd rather save up for a TL or gas money). Glad you like em and this car is coming along nice!
Far less deserving cars have gotten lambo doors
#100
I have to admit it looks pretty good, keep up the good work!
#102
@AcuraSpook and 1foxbody thanks!
can anyone recommend a good quality brake fluid? I read racing fluids, like ATE Blue, absorb water (which of course lowers the boiling point) much faster than OE grade DOT3 fluids and to use Honda DOT 3/4 brake fluid instead or you run the risk of corrosion. What would you do?
#103
Just get the normal off the shelf Dot 3/4 fluid. Dont run Dot 5, you have to flush the entire system, otherwise it will damage the seals. But most importantly its not compatible with ABS.
#109
The color is nice. Really pops.
#111
Not in this thread.
#112
THANKS @ civicdrivr, AcuraSpook, gnuts.
rebuilding the caliper was easy. The hardest part is taking out the pistons since i dont have an air compressor. I just went down to the tire shop and ask if they could pop the pistons out and they did since i was there for a tire rotation any ways.
**One thing i will say is the that the rebuild kit DOES NOT include 4 of the little seals you will need to re use the originals, so dont throw those away**
#113
Hey guys im reaching out for help again, This time im gonna work on all the suspension parts since i have started to get a clunking sound in my front left suspension... what should i replace, im trying to make 1 order to save on shipping so far i have this list
Radius rod bushings - Moog
Sway bar end links front and back-Moog
Outer tie rods-Moog
Front Lower ball joint-Moog
What else should i change like inner tie rod, Upper arm bushings or ingalls arm?
Anything in the rear suspension or Wheel Bearings?
Outer tie rods-Moog
#114
Take a look at the lower control arm bushings. If theyre cracked, replace them. Its easier to replace the entire arm. Same with the rear.
#115
thanks civicdrivr i have decided to change all the bushing pretty much. I searched the forums for the front suspension and know what to get except for the upper arm. I dont know if i should get the Igalls arms? I dont if those bushings are rubber or poly? I rather have poly
All so didnt find anything on the rear suspension for bushings ? What does everyone replace there Rear upper an lower arms/bars with?
#118
I been working on the car just waiting on a few parts if they ever get here I ordered some super grease online 3 times and they were all cancelled then i called 3 local shops they didn't have any of it so i had to put an order in with one of the shops hopefully i get it today........any way here is my rear big break kit jk
#120
So after 150,xxx miles on the car the auto transmission has given out. I had it replaced by the dealer at 32,xxx miles. So im looking into having it converted but i want to find the parts and take it to get it rebult before i have someone install it for me so i can save some money.
My question is Is the 07 or 08 TL S 6 speed the best trans? will it work and/or is it the same as getting a accord 6speed and adding the LSD. is there a gear difference? is the TL S ^ speed stronger than the accords?
