Oxidation on headlight cover
Old 02-10-2008, 03:19 PM
A clean ride is in
treyster's Avatar
Guys, what's the best stuff to use on headlight covers. I've been going to a carwash and now it seems like my covers are getting some kind of oxidation on them. Is there some kind of cleaner I can use on them?? I saw something at Discount Tire but it was over 50 bucks. I may have to post a pic if needed
Old 02-10-2008, 03:37 PM
ridin slow'n'low
smokendsm's Avatar
I used meguiars plastx or something like that. Supposed to be a plastic polish.
Try that before trying the more expensive stuff.
Old 02-10-2008, 04:21 PM
fuzzy02CLS's Avatar
From FAQ.....
Using Meguires Plastx to clean Headlights:
https://acurazine.com/forums/showthr...ghlight=plastx
Wetsanding Headlight Lens Scratches:
https://acurazine.com/forums/showthr...ight=wetsanded
Old 02-10-2008, 06:47 PM
A clean ride is in
treyster's Avatar
thanks guys!!
Old 02-11-2008, 01:33 PM
I just recently wetsanded mine and polished them. They were really beat up after 250k+ miles
Before
Wetsanded
After
New Light
Old 02-13-2008, 10:18 PM
Zombie Serg's Avatar
Wow, I think I will be taking a trip to the Autoparts tomorrow!
Old 02-20-2008, 05:12 PM
dont be mad
TypeStylinOnU's Avatar
are u talking about condensation inside the headlights? or scratches and wear on the outside of the headlight?
Old 03-24-2008, 08:50 PM
madogstarr's Avatar
Hey, I've been checkin out products. One thing was clear, try a non abrasive product first if the lens is not already scratched. Once you use a rubbing compound or wet sanding you may damage the lens. De-oxidation products are out there, use a small amount on a paper towel and wipe. cleans off all that yellow stuff!!
If that does not do the trick then go into rubbing compounds, like PlasticX. There are $50 kits available with different levels of grit for rough to smooth grinding available if you have extreme damage.
Last you may need wet sanding. This is extreme and you may end up applying it on a regular basis to keep up appearances.
Old 04-15-2014, 09:37 PM
B Dub's Avatar
Ok, so a little late to this but good info below.
After a little researching I came across this Consumer Reports article: Headlight Restoration Kit Buying Guide and decided to go with the Sylvania Headlight Restoration kit.
It worked perfectly and I hd enough left over to do a 2nd set of headlights on one of my other vehicles.
Instructional Video: Here
Will post some pics...
Old 05-22-2014, 11:19 AM
swabbie82's Avatar
I saw on youtube that toothpaste works and I tried it . . .DAMN!! It took alot of it off mine; not as good as Meguiars or any of the others on the market I'm sure, but I can definitely tell the difference. Plus, they have a minty fresh smell lolol . . .
mlody
12-04-2019 02:11 PM
BIGxRED
10-19-2015 10:47 PM
rockyboy
09-29-2015 12:05 AM
AmplifiedDetails
09-24-2015 02:55 PM
Quick Reply: Oxidation on headlight cover
