Tie Rod Question
Old 04-23-2024, 11:28 PM
ballen5150's Avatar
Tie Rod Question
Does this look like a normal tie rod failure? The tie rod bellows looks like rats ate it. Grease everywhere.
There are no symptoms when driving or strange noises when turning wheel so Im wondering how urgent it is to fix it.
urgent to fix
Old 04-24-2024, 09:58 AM
BROlando's Avatar
Received 1,170 Likes on 880 Posts
That's a steering rack boot issue.
No idea why this happened.
Yes, you should fix it instead of just driving it. Waiting until there is a problem is going to get massively expensive, because it will be a problem with the steering rack.
I recommend buying the boot and clamps from an Acura dealer.
You will need an alignment once this is done.
ballen5150 (04-24-2024)
Old 04-24-2024, 11:16 AM
ballen5150's Avatar
Do you think it is a leaking steering rack and that's steering fluid?
Old 04-24-2024, 01:19 PM
Received 1,750 Likes on 1,404 Posts
urgent to fix
As BROlando suggests you are going to want to get that fixed quickly.
Looks like a big chunk of the boot has been removed?
Either by furry fiends or solid hit from road debris?
Here is where you can notate / research OEM parts and then shop the web for the best deal.
P.S. Gear Box - 2007 Acura TL 4 Door BASE (NAVIGATION) KA 5AT (acurapartswarehouse.com)
Old 04-24-2024, 08:12 PM
BROlando's Avatar
It does look like a fluid leak, but could also just be grease. I would check for that to see if rack seals are bad.
Old 04-24-2024, 08:58 PM
ballen5150's Avatar
endoscope of tie rod
Thanks for all the input. Here are some shots of tie rods and other oil stained areas further up. P/S reservoir is at the minimum fill line so it seems like its a very slow leak. Outer tie rods are shot so plan to replace tie rods (inner and out), bellow and clean up as best as possible.
With slow leak Im hoping that rack can wait but open to opinions on urgency
endoscope of inner tie rod
endoscope in bellows
endoscope of oil stain at far end of inner tie rod
oil stain near far end of bellow
Old 04-25-2024, 11:17 AM
BROlando's Avatar
I would just fix all of it at once. You're taking most of the rack apart to get to the inner tie rods
Also...buy your parts from an Acura dealer. I wouldn't take a chance with aftermarket "OE replacement" tie rods or seals. You only want to do this once.
The following 2 users liked this post by BROlando:
ballen5150 (04-26-2024), jeffstlnote (04-25-2024)
Old 04-26-2024, 07:35 PM
ballen5150's Avatar
Any advice on breaking free a seized jam nut?
Old 04-26-2024, 09:11 PM
BROlando's Avatar
The outer tie rod jam nut?
Unfortunately, heat is the only real way. BUT...you're replacing it, right? So who cares? Cut it off if its faster. Get medieval
Old 04-26-2024, 09:55 PM
ballen5150's Avatar
Number 18
yes replacing
I dont have a sawzall or grinder and am limited to what my condo association/ neighbors will put up with
Im wondering if I could take both the inner and outer off as a unit with channel locking pliers on 1.
Old 04-26-2024, 10:52 PM
BROlando's Avatar
That's not likely to come off with pliers
You can wait until tomorrow and buy a MAPP torch kit from a hardware store. An angle grinder is probably cheaper though.
Old 04-27-2024, 10:20 AM
ballen5150's Avatar
There is video online of a guy using channel locks so may try that first. If not Ill be getting a torch
Old 04-27-2024, 10:59 AM
Received 8,611 Likes on 6,650 Posts
I doubt youll get enough torque with channel locks but good luck
Old 04-29-2024, 11:25 AM
ballen5150's Avatar
Thanks for the help. Propane torch, long crescent wrench and 3 lb hammer took the Jam nut off with a couple good whacks
Any tips on after market parts. Dont want to spend for OEM as Im probably going to sell within a year. I read lots of people using moog. Dorman premium is listed as the best they have on RockAuto.
https://www.rockauto.com/en/catalog/...e+rod+end,7428
Also I read that the drivers side bellows was larger than the passenger side but the Acura dealer and acuprapartswarehouse shows its the same for both sides. Should I also use the acura bellow inner band? Does it require a special tool?
Old 04-29-2024, 12:16 PM
BROlando's Avatar
I can't recommend any aftermarket, OE replacement brands. They've all been failure prone in my experience. Maybe someone else can.
The genuine Acura stuff is only like $20-50 more than aftermarket, no? Why would you chance it?
You need a band crimping tool, IIRC. I don't think these are the type that have a detent.
Old 04-29-2024, 01:35 PM
ballen5150's Avatar
Im seeing OEM inner for over 100 and outer tie rod for 50.
Moog is 50 tot. I dont drive the car much so dont want to put too much into it.
Old 04-29-2024, 02:42 PM
AZ Community Team
Legend2TL's Avatar
Received 4,039 Likes on 2,513 Posts
I'd be OK with TRW aftermarket for both tie rods. TRW make quality suspension aftermarket parts, AFAIK TRW still make many OEM suspension components.
Old 04-29-2024, 09:40 PM
ballen5150's Avatar
I ordered the Moogs from Rock Auto before I saw the TRW recommendation.
I was thinking that if my jam nut was so frozen how have they been doing my alignments? Does this mean I should unfreeze the other side before I take for an alignment or better yet find a more trust worthy shop.
Old 04-29-2024, 11:07 PM
BROlando's Avatar
They're probably heating it up, loosening it, and then tightening it back up. Or they have better tools (no offense meant).
You should anti seize the adjustment thread and locknut to prevent future issues.
The torque on that jam nut isn't super heavy either. Now's the time to look that up.
*Definitely* don't over torque for the castle nut either.
ballen5150 (04-30-2024)
Old 04-30-2024, 07:31 PM
ballen5150's Avatar
No offense taken.Appreciate the input.
I noticed some people will pack extra grease into the inner ball joint. and along the inner stem. Is that needed?
Im planning on using blue thread lock on the inner Tie rod threads and anti seize on the jam nut and outer tie rod threads
eddie_obie
22
06-07-2011 08:25 AM
erick3
3G TL Photograph Gallery
24
07-29-2010 03:57 AM
FirePR2002
06-14-2010 06:30 PM
JterrorC
06-05-2009 11:51 PM
TeknoKing
09-06-2008 12:32 AM
Quick Reply: Tie Rod Question
