Light Bulb Spec.'s ...?
Old 04-25-2024, 03:35 PM
3rd Gear
Sam_I_Am's Avatar
Hey All....I've had my 2020 for about 3 weeks, now..... It's not being used as a daily driver...Been driving Honda's for......(Decades)....I traded my 5th Honda, in ...on my MDX...so, yes I'm new to "ACURA"
My ultimate goal is to get the complete list of every light bulb in my 2020 (Advance) ....online research.... is poor, just a jumble of 15 web site all have different numbers......
even Acura diagrams don't give all bulb info...?
BUT.....I would be willing to settle, for the exact spec.'s on the overhead MAP LIGHT bulb(s) ..... I'd like to change the bulbs to an LED BRIGHT WHITE bulb.
Specifically the TWO lights right above the driver (/ passenger) .......N O T ...any of the DOME lights for the 2nd row OR Cargo (compartment)
OR maybe you know the exact Acura part number (just for the bulb(s) ......and perhaps I can Cross Reference it. to an OTC bulb ........Any help would be great.......Thanks
Old 04-25-2024, 05:42 PM
Received 8,595 Likes on 6,639 Posts
I googled "2020 Acura MDX bulbs":
https://www.mdxers.org/threads/upgra...lights.177724/
Old 04-25-2024, 06:10 PM
3rd Gear
Sam_I_Am's Avatar
Yeah, a lot of that thread are talking about the footwell light bulbs.... Which I am also working on......my footwell lights DO NOT come on when you open the door......not sure whats going on there
took both bulbs out....and both look good.....as in......not blown. Thinking it might be fuse but I haven't gone that far yet.
I own the Advance trim level, so I don't know if the footwell lights are standard ONLY on the Advance trim....or if the footwell lights come with ALL trim levels...???????
the footwell bulbs on my 2020....are DE3022.. Acura Part number 34295-SD4-003 ......12V 5W. these CAN be substituted with the DE3175 ....both types should work.
The Dome Lights (second row seating & Cargo area.....can NOT be changed....they are fixed to a circuit board...you can not change those
I am Still searching for info on the MAP LIGHTS........anybody......?
Old 04-25-2024, 07:59 PM
Pop off the cover and take a pic and measure the bulbs and then compare them to online. Theyre either going to be festoon or 168 bulbs
Old 04-26-2024, 11:43 AM
3rd Gear
Sam_I_Am's Avatar
Thanks..... I did figure out why my interior lights weren't coming on.....it was the #30 fuse, was blown....... in the fuse box by the drivers left foot.
I took the lens cover off the MAP lights .....those bulbs are in there so tight....I can't even tell what TYPE of bulb it is......although it may ALREADY be LED...from the factory.... not sure
I'll look again, but it's so tight I may not want to mess with it....I sure don't want to break anything...!!!
Thanks for your help
Phambam12
10-01-2012 10:19 PM
TLBaller
1G TL (1996-1998)
12-25-2009 06:14 PM
PearlyWhite
12-11-2008 10:49 AM
bigmark89
04-21-2007 12:32 PM
KaMLuNg
1G TL (1996-1998)
15
07-11-2006 08:13 PM
Quick Reply: Light Bulb Spec.'s ...?
