Speedometer, temp gauge, tachometer, and fuel not working
Old 04-18-2024, 10:34 PM
vii3tkidd's Avatar
Hey guys,
Anyone ever had an issue where the speedometer doesn't work but still lights up?
I've attached a photo below all the windows roll down fine, and temp adjustment works as well.
Also there's no cruise control.
Old 04-19-2024, 08:28 AM
John from PA's Avatar
Lacking any specific guidance, I’d be checking fuses and the appropriate wiring harness.
Old 04-21-2024, 01:43 AM
whitetiger5's Avatar
Maybe something wasn't plugged in properly when the illumination lights were converted/replaced?
Thefireball (04-21-2024)
Old 04-21-2024, 05:25 PM
I am dumb
Thefireball's Avatar
Check interior fuses. If all fuses are good, then something was maybe left unplugged to the gauge cluster. But if your cruise control isn't working, then I'm betting fuses.
Old 04-22-2024, 11:05 PM
Jon M's Avatar
Are you saying that the cruise control light is out but the cruise control is working or that the car won't engage the cruise control. If it is the latter it is probably the little peddle pad stopper on the brake peddle assembly. The Cruise Control light on the dash won't come on unless the Cruise Control is engaged.(25 MPH and up). Without that little pad (rubber/plastic), which presses into a hole in the metal bracket and then you have to adjust Item #3 such that the brake lights are off and the cruise control will engage. When the pad corrodes (age) your brake lights will stay on all the time (draining the battery). Sometimes the pad develops an indent and while the brake lights are off the cruise control won't function.
Item #4 P/N 46505-SA5-000
Old 04-26-2024, 12:02 AM
vii3tkidd's Avatar
We can close the thread. Ended up being a dead cluster. Replaced the cluster and everything works fine now.
derrek116
01-11-2021 05:10 PM
Dominik W
1G RDX (2007-2012)
06-11-2020 11:16 AM
XGaSpAcHo
04-09-2010 09:08 PM
rchuang
1G TL (1996-1998)
22
09-25-2005 02:53 PM
Quick Reply: Speedometer, temp gauge, tachometer, and fuel not working
