Need help acura cl type s clutch kit installation
Old 04-07-2014, 12:34 PM
Vic87's Avatar
Just did my clutch master clutch kit now my car won't pass 2 k rpm throwing codes for crank positioning sensor and map sensor but with the stock clutch it was fine can some one plz help and also the aftermarket flywheel don't got the pin that the stock one has was I supposed to remove it and install it on the light weight one
Old 04-07-2014, 12:54 PM
3.5 psi
gnuts's Avatar
Not sure what to tell you but it seems others have had the same problem:
https://acurazine.com/forums/showthr...=864323&page=2
Old 04-07-2014, 12:57 PM
Vic87's Avatar
I called clutch master they telling me is not the kit dat they never had problem with their kit I wasted so much money for nothing
Old 04-07-2014, 12:59 PM
Vic87's Avatar
Some one got to have the answer if any one got the answer plz text me 1201 852 0052
Old 04-07-2014, 03:17 PM
Vic87's Avatar
Any one else had problem with this dam kit
Old 04-07-2014, 04:09 PM
Vic87's Avatar
Some one help
Old 04-07-2014, 09:23 PM
Unregistered Member
Karanx7's Avatar
Jesus christ dude, put some periods at the ends of your sentences.
Old 04-08-2014, 07:49 AM
Vic87's Avatar
I don't like to use periods lol
Old 04-08-2014, 03:23 PM
Unregistered Member
Karanx7's Avatar
Unfortunate, I don't like to help people who have poor grammar.
Too bad too, since I recently installed a lightweight flywheel successfully.
Old 04-08-2014, 03:34 PM
Vic87's Avatar
i really need the help.I would like all the help i can get.But i called clutch master and they told me i need to install the pin that my stock flywheel brings.And i didnt install that pin to my aftermarket flywheel .Hopefully thats the problem.Karanx7 so if u can be a nice guy and help a fellow member that will be very much appreciated.Thank you very much
Old 04-08-2014, 03:47 PM
Unregistered Member
Karanx7's Avatar
Lol now I feel bad. Looks like you have no choice but to open up the clutch housing again. I used the AASCO lightweight flywheel which looks identical to the Clutchmasters one.
Do you still have the pin? or did you throw it away?
Vic87's Avatar
some one help me out. Dont want to take my trans out again and have to take it out again.
Old 04-08-2014, 03:48 PM
Vic87's Avatar
I still got the pin in my stock flywheel
Old 04-08-2014, 03:49 PM
Vic87's Avatar
I was told by clutch master that the pin is like a sensor. Thats why my car wont pass @k rpm
Old 04-08-2014, 03:50 PM
Vic87's Avatar
*2k
Old 04-08-2014, 03:51 PM
Vic87's Avatar
When u installed your flywheel did u use the stock pin
Old 04-08-2014, 04:02 PM
Vic87's Avatar
Karanx7. If u want u can text me what i need to do at 201 852 0052
Old 04-08-2014, 04:22 PM
Unregistered Member
Karanx7's Avatar
You have no choice, the trans must come out again. No way to put the pin back in without taking the trans apart.
Old 04-08-2014, 04:32 PM
Vic87's Avatar
And if i install the pin will my car drive fine. or i have to do something else,
Old 04-08-2014, 04:34 PM
Vic87's Avatar
And wat kind of clutch u put in yours.
Old 04-08-2014, 05:10 PM
Unregistered Member
Karanx7's Avatar
I used the OEM clutch and OEM PP, with a lightweight flywheel.
I almost didn't install the pin because I couldn't get it out of the old OEM flywheel. But I figured it would be best to use it just in case, and banged it out.
o0o0o0 (04-08-2014)
Old 04-08-2014, 05:19 PM
Vic87's Avatar
When u bang it out did it get damage. Because I was trying to pull mines out with plyers. And the corners got a lil ding up. Does that matter that they got a lil dinged up
Old 04-08-2014, 05:26 PM
Unregistered Member
Karanx7's Avatar
Oh I dinged the shit out of mine, but it worked fine after I put it into the lightweight flywheel. Just make sure it's not so deformed that it won't fit in the new flywheel.
Vic87 (04-08-2014)
Old 04-08-2014, 05:29 PM
Vic87's Avatar
Thanks man hopefully that's the problem on mines.
Old 04-13-2014, 02:23 PM
Vic87's Avatar
Back to square one. Took the fucking trans back out reinstall it with the pin and still not fucking wrking. What else can the proble be. No one should buy clutch kit from clutch master
IIDXholic
10-08-2015 07:53 AM
Glorygang600
09-05-2015 01:17 AM
nuldabz
09-03-2015 05:49 PM
voigt
09-02-2015 10:44 PM
EvilVirus
08-31-2015 05:24 PM
Quick Reply: Need help acura cl type s clutch kit installation
