Accord springs on the CL?
Old 04-02-2014, 03:14 PM
s14dk's Avatar
Hi guys,
Im in the middle of ordering lowering springs for the CL-s and have been hearing that accord coupe springs from 98-01 will work on the 01 CL? The price difference is $65, so I thought i'd come here and confirm with you guys.
All input will be greatly appreciated.
cheers.
Old 04-02-2014, 04:32 PM
lowrd on tein CS biatch
CL-S progression 01's Avatar
yes they work but the spring rate is different cause the weight on the accord is less, especially in the front iirc.
I think I have accord springs on my car i bought some tein coilovers used off kijiji and the guy told me they were for my car, upon install the front mounts were too small so i dremeled out a lil more real estate where the holes in the top mount are and its all fine.
but i think the coils are softer than they should be..
but i do love the ride so i am happy with it. however over big bumps i think the shocks bottom out... only happens once a month but just though i'd let u know.
personally i never would have bought them if i knew they were not made for my car. so u live and u learn.
Old 04-02-2014, 07:02 PM
s14dk's Avatar
cool thanks robbb
Old 04-03-2014, 06:08 AM
YeuEmMaiMai's Avatar
the accord is about 200lbs lighter so if you use those springs the car will sit lower and the shocks will work harder to control them.
Old 04-03-2014, 11:16 AM
DuwayneWebPro's Avatar
$65 to ensure something fits/functions properly on your car = priceless
Old 04-03-2014, 11:19 AM
i called tein and they said our car is supposed to have 7 in the front and 4 in the back..
YOU can go 1kg higher or lower on springs for your as i was told by tein yesterday on the phone
so say u buy coilovers that come with 7 and 4 kg springs. the shocks are valved for that weight/spring ratio... you can weaken or stregthen the springs by 1 kg in the front and or the back without worrying about the shocks... if u got more than 1 kg off you may damage the shocks then cause they are valved for that set-up.
i inquired about stiffer springs in the front yesterday and that's what i found out so...
hopefully this is going to guide someone in the right direction.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
adreano17
09-29-2015 08:48 AM
MrHeeltoe
09-28-2015 05:43 PM
Bielikb96
09-28-2015 10:45 AM
Quick Reply: Accord springs on the CL?
