3.7 stroker kit soon to be sold
Old 03-12-2013, 07:22 AM
J-series addict
yungone501's Avatar
Be on the lookout from a company called TB Motorworx.
They recently announced the news.
Also will be making full on race springs and valves for the J series.
The following 6 users liked this post by yungone501:
1foxbody (03-12-2013), ANC297 (03-16-2013), DEPTLS (03-09-2014), Sonnick (04-10-2014), Stephen00TL (03-12-2013), thisaznboi88 (03-12-2013) and 1 others liked this post. (Show less...)
Old 03-12-2013, 07:51 PM
03 acura cl type s
rush's Avatar
bout time
Old 03-12-2013, 08:52 PM
Unregistered Member
Karanx7's Avatar
Any details or anything? Where is the news? Sounds sick
Old 03-12-2013, 09:05 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
sounds interesting. Wonder what the cost will be
3.7L Nitrous Breathing CL
richardparker's Avatar
When I was going to order custom valves they were 26 each from manley.
Hope they come out with flat face valves.
Old 03-12-2013, 09:09 PM
fsttyms1's Avatar
I would like a set of them too to help increase compression. If im not mistaken doesnt KMS offer them?
Old 03-12-2013, 09:12 PM
I think for the accord but not the j32a2.
I think
Old 03-12-2013, 09:15 PM
2600lb CL
Cocoa's Avatar
I'm just curious of the cost in comparison to the route you can already take to achieve that 3.7L displacement. As for the valves and springs, I'm wondering how they'll differ from bisimoto's and kms's.
Old 03-13-2013, 05:02 AM
Atlas.46's Avatar
I actually was posting on one of the pictures and they message me details. I was talking to them for a little while.
"We have 2 kits currently available . One kit uses Oem 96mm crank with our spec rods (over 6in) and pistons with a 1.000 compression height. The other kit we have uses a billet Crower 100mm stroke crank. The couple we have sold we ask the customers which engine so that way we know what spacing to put on the crank . The 100mm is made to order. We don't stock it. All the parts are 100% USA made"
I asked about clearance and street or track use only for the 100mm crank..
"A little bit of clearance needs to be made for the 100mm crank. Even though the crank is billet and dam near bullet proof we only recommend the 100mm stroke for track only .(increased rod ratio /angles)"
They are also selling springs and valves. I think they are working on cam gears too.
me- are your valves stainless?
"Yes they are stainless . As you know the J lacks in the cam department because of the cylinder head. Lift is limited . But we have figured out ways around that."
"We have billet cam cores that are in the test phase right now and will be released very soon! Yes .500 + lift!"
Also making cam gears cause they said this. I think...
"Cam gears too but that was a nightmare because the different years have different cam pickups"
Pricing:
"We sell the 96mm crank stroker kit for 3200 , includes our spec pistons , and rods. The 100mm uses a billet crank , our spec rods and pistons that is 5300.
The valves are $26 a piece , and the springs are $22 a piece . The springs we sell are the only ones that will work with our cams"
Old 03-13-2013, 05:04 AM
Atlas.46's Avatar
and what the fuck... just had dejavu scrolling up this post like i seen it before..
Old 03-13-2013, 10:39 AM
fsttyms1's Avatar
Pretty pricy as you can get all oem parts and upgraded kms springs, valves and block guard for less.
1foxbody (03-13-2013)
Old 03-13-2013, 12:11 PM
03 CLS-6
1foxbody's Avatar
Way too expensive for my likings. I'll stick too spraying the piss out of my setup lol.
yungone501 (03-13-2013)
Old 03-13-2013, 07:07 PM
J-series addict
yungone501's Avatar
Interested in the cams and how they achieved over .500" lift without modifying the head.
Spd0lit (09-05-2014)
Old 03-13-2013, 08:36 PM
They would have to grind them right to the core or cut the heads to make somesort of cam caps.
1foxbody (03-14-2013)
Old 03-14-2013, 06:10 PM
03 CLS-6
1foxbody's Avatar
Ding Ding!
Old 03-20-2013, 03:29 AM
03 acura cl type s
rush's Avatar
Originally Posted by 1foxbody
Ding Ding!
How's the 3.5?
Old 03-20-2013, 12:39 PM
J-series addict
yungone501's Avatar
Here's what I would do:
There are four bearings total. The outer two bearing are extremely thin at their smaller point. The center two have alot of material to remove to allow for boring and running over sized cam bearings. The front cam bearing would need to be machined as a removable cap yet maintaining factory size bearings due to being unable to over bore the bearing journal. This is the most economical and logical explanation I could come up with.
I have plans on attempting this but my machinist is temporarily out of commission.
Given that I can obtain accurately spec'd bores all the way through the head...I could then have a set of cams made.
There's a few other smaller issues that would need to be worked out on the head but that's all I'm giving up.
Old 04-10-2014, 01:05 AM
All motor
Sonnick's Avatar
They have all kinds of good stuff; a bit on the expensive side, but there really aren't too many other choices.
mlody
12-04-2019 02:11 PM
nj2pa2nc
08-19-2016 06:18 AM
adrian_s2k
1G RDX (2007-2012)
23
01-12-2016 04:25 PM
dirleton
20
10-16-2015 01:48 PM
Quick Reply: 3.7 stroker kit soon to be sold
