pool of water on driver side carpet after big rain
hi, hoping someone may know the cause of this issue and a fix to it.
after a pouring rain, noticed a puddle of water pooled on the front driver side carpet when i press my hand down on it.
other sources i've googled mentioned drain clog on sunroof or a/c drain line clogged, i will have to check the drain hole on sunroof to check if that's the cause of my water issue, can't be a/c since it's not hot enough for summer.
i'd appreciate if there is a picture or manual online that pinpoint where the drain clogs are on sunroof and other drain holes like on the windshield, which i suspect may be another cause of the leak.
this is a 2010 Acura MDX (technology package i think). thanks!
separate question, what's a good tire recommendation to replace on 2010 acura mdx? all 4 are due for replacement soon, and only costco tire shop nearby and independent tire shops with mixed reviews.
Pop off the A pillar on the driver's side, you'll see if there's a leak.
I'm partial to Michelin tires
where would clog in the windshield drain hole cause leak? wanted to consider all possible clogs.
